This doesnt look right
Old Feb 13, 2015 | 03:39 PM
visa_broke's Avatar
visa_broke
10 Year Member
Default This doesnt look right
V reg 2 litre petrol focus,not starting.it's getting fuel and a spark but struggling to fire,no codes are showing on a bluepoint scanner.anybody got any ideas or is it just the left cam in the above picture is out slightly and its slipped on the belt.
Old Feb 13, 2015 | 03:42 PM
mark826's Avatar
mark826
Timing is definitely out on that one
Old Feb 13, 2015 | 03:45 PM
visa_broke's Avatar
visa_broke
10 Year Member
Thanks for the quick reply, thats what we suspect.
Old Feb 13, 2015 | 04:03 PM
visa_broke's Avatar
visa_broke
10 Year Member
the picture was taken at tdc,looks like the left cam has slipped. Do you say that valves will be bent slipping by that much?
Old Feb 13, 2015 | 05:28 PM
mark826's Avatar
mark826
Hard to say. I know they run very close normally so I'd be preparing for the worst. I use a little camera on a stick through the spark plug holes to check if there is any evidence of contact.
Old Feb 13, 2015 | 05:30 PM
mark826's Avatar
mark826
Pull the exhaust manifold off the front of the engine you will get a decent view of the valves from there
Old Feb 14, 2015 | 02:05 AM
visa_broke's Avatar
visa_broke
10 Year Member
Thanks for the reply mark, I will see if we can get access to one of them camera's again when we do it.
Old Feb 17, 2015 | 11:45 AM
roger69's Avatar
roger69
I'm not a mechanic but I have changed many zetec & other cam belts & noticed that the alignment slot on the left can is out about 10degrees anticlockwise at tdc they should be parralell.If you havnt got an alignment tool usually ape ice of 6mm bar should do.
Old Feb 17, 2015 | 07:03 PM
Harryh24's Avatar
Harryh24
time it back up and do leak test, you will soon see if it's bent valves.
