Master cylinder/servo upgrade
Fitted a compbrake pedal box to my s2 when i noticed my servo was leaking, can't stand the peddle feel so it'll be coming off,,
I know everyone fits mondeo servo set ups, supposedly a 25mm master cyl?
has anyone got any decent pics of them fitted, or part numbers for correct one, all the mk3 mondeo ones i look at seem to be 23mm master cylinders?
I read somewhere that Mitsu Evo 7,8,9 servo etc can be fitted, not scared with a welder to modify as required so might get on eBay and look at them,
any info or thoughts appreciated!
cheers
cheers
Sorry mate i thought id replied!!
In all fairness i could prob get used to it,, but i really have to stamp on the pedal to get desired effect,,obviously not being servo assisted will do this!
But maybe with it being compbrake low quality master cyls this could make it worse? not had experience with better makes like wilwood etc so can't really say!
cheers
scott
cheers
scott
cheers
scott
Cheers for reply m8..the stamp on break was kinda reason ah thot of that route.before ma s2 came off the rd it was running wilwoods up front and cossie on rear.abs etc removed but,master had been changed but not sure with wot..pedal was really spongy and hard to judge and if to hard the rears would lock up....bk to the drawing board again lol
