cosworth ybt engine for sale
cosworth 2.0 ybt engine for sale as cancelled the project
the engine was built by joe at hart power
engine spec
cosworth 200 block
coworth racing pistons 0.5 size from cosworth
cosworth conrods with arp bolts
acl bearings
new spec oil pump from cosworth
new exhaust camshaft
newmans double valve springs
new ina hydraulic cam follower
newmans bd14 inlet camshaft
10 long studs machined
new gen was pump machine for 10 stud
head reworked
sodium filled valve where needed
wrc headgasket
mountune wrc baffle sump
4x4 big wing sump
2 wd exhaust manifold
oil cooler
new inlet manifold with 76mm audi throttle body dbw
mountune an6 fuel rail
wrc distributor blank
wrc camshaft sensor fitted to cam cover
wrc crankshaft pulley and sensor
new seals and gaskets new bosch coil pack
coil pack ht leads
engine was built to run a life f88 ecu set up for 500bhp
any question please ask looking for £5000 ono
link to ebay
http://www.ebay.co.uk/itm/1816611872...84.m1555.l2648
engine spec
cosworth 200 block
acl bearings
head reworked
wrc headgasket
4x4 big wing sump
oil cooler
coil pack ht leads
link to ebay
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
