T34, where to get one?
Old Feb 6, 2015 | 02:44 PM
Marc sierra's Avatar
Marc sierra
Default T34, where to get one?
Im looking to upgrade my sapph 4x4 with a T34. So what's the best place to get a T34 with a 360 degree race bearing and uprated seals?
Old Feb 6, 2015 | 02:49 PM
Jay,'s Avatar
Jay,
Sponsor
I dont think anyone builds them now just refurbs them
Old Feb 6, 2015 | 03:12 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Have a chat with 'wilky' on here or 'bernies blowers' on ebay. Good rep and well priced, same guy.
Old Feb 6, 2015 | 03:16 PM
RS 5tu's Avatar
RS 5tu
Bits are available to convert a T3 compressor housing to T34 spec thats what i did. But you would still be on the .48 rear unless you found a .63 for sale also.
maybe a option?
Old Feb 6, 2015 | 03:21 PM
L1AM_RS's Avatar
L1AM_RS
Tried CR?
Old Feb 6, 2015 | 03:32 PM
Marc sierra
I haven't tried anything yet. I wanted to know with which suppliers people have good experience. BTW, I will probably keep the .48 exhaust housing, so I can simply use my current housing if I'm correct. But If I can get one with a .63 or a .55 I will put that on the shelf as future upgrade option.
Old Feb 6, 2015 | 03:37 PM
RS 5tu's Avatar
RS 5tu
there is a couple on ebay (uk) now maybe worth a look?
Old Feb 6, 2015 | 04:12 PM
Marc sierra
I only see a second hand T34 on eBay and a new one for an escort RS turbo. Is the rs turbo one the same as a Cosworth one, except for the exhaust housing? A few days ago there was a T34.48 for a cossie on eBay from the same supplier, but it was a lot more expensive than the RS turbo one.
Old Feb 6, 2015 | 04:19 PM
scoooby slayer's Avatar
scoooby slayer
if it was me id be wanting a modern roller bearing billet turbo there will be a considerable increase in boost threshold, maybe a gtx3071 im sure there available on a cossie rear aswell, I got 2 gtx3071s on my car there great turbos will run 480 hp each and there restricted in mine aswell.
I found the rear housing for the gt30r and gt35r
http://www.atpturbo.com/mm5/merchant...&Category_Code=
that will bolt directly to your stock yb exhaust manifold so you can fit a modern turbo
Old Feb 6, 2015 | 04:23 PM
Marc sierra
I've looked into that and you can get a GT(X)3071 or 76 with a Cosworth turbine housing. But those need to be live mapped on the engine and since i'm outside the UK that's no real option for me.
Old Feb 6, 2015 | 04:32 PM
scoooby slayer
im sure stu at motor sport developments could do you a chip no problem mate
Old Feb 6, 2015 | 05:56 PM
MARCOSWORTH's Avatar
MARCOSWORTH
Did you asked Gerry Knubben, he might be able to help you out?
Old Feb 6, 2015 | 06:14 PM
Marc sierra
I already asked both MSD and Gerry Knubben. They both say the GT3071 will surge on a standard engine, that's why it would need a proper setup. Besides that James from MSD said the GT3071 would spool about the same as a T34.63. So it's a lot of trouble to go GT3071 and because of my standard gearbox I can't really benefit from the higher power either. That's why I'm back at a T34. But Gerry can't supply a T34 either.
Old Feb 6, 2015 | 06:23 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I can supply you a t34
Old Feb 6, 2015 | 06:30 PM
costina's Avatar
costina
Live long and prosper!!
Tony, any idea what it costs to convert a T34/63 maram shafted to T38 spec?
Old Feb 6, 2015 | 06:36 PM
Turbosystems
Super Moderator
That would depend if any of the donor unit could be used
you'd probably be better off selling the old t34 and jut buying one of our brand new t36 billet beasts
Old Feb 6, 2015 | 06:43 PM
costina's Avatar
costina
Turbo is spot on so what will be the cost? and the T36?
Is that what Steve 4i uses?
cheers
Paul
Old Feb 6, 2015 | 06:45 PM
Jay,'s Avatar
Jay,
Sponsor
I would have a tt36 over a t34 anytime
Old Feb 6, 2015 | 06:48 PM
Jay,'s Avatar
Jay,
Sponsor
cheers
Paul
Paul Steve has the big brother tt38
Old Feb 6, 2015 | 06:51 PM
Marc sierra
Tony told me the T36 will have quite a bit more lag than the T34. To be honest I'm a bit lost with all the different opinions, that's why I think going for the tried and tested is best.
Old Feb 6, 2015 | 07:00 PM
costina's Avatar
costina
Think thats what i need lol
Old Feb 7, 2015 | 01:03 AM
scoooby slayer
If thats the case then a gtx28 on a T3 housing would be ideal, 400 hp and should easily outspool a T34, bb turbos are so much better it's night and day ime
Old Feb 7, 2015 | 07:20 AM
Marc sierra
But there is no exhaust housing to fit the GT28 directly, like there is for the GT30.
Old Feb 7, 2015 | 07:39 AM
scoooby slayer
there are a few options, I have used one of these on a cosworth as all it needs is an rs500 rear 5 bolt flange wastegate housing and its then a direct fit
or this flange can be used on the above housing and your downpipe will just need a v band flange welding on
then there is this complete wastegate assembly, but it needs a iirc delta flange adaptor to bolt on which will then make it direct fit for your downpipe
I still don't see why you cant run a gt3071 though, it just needs running at lower boost so it doesn't surge.
I will try and find a link to the 5 bolt wastegate housing I used, as I had one on my saph and it looked like an rs500 rear housing.
Old Feb 7, 2015 | 08:28 AM
Tinshaw's Avatar
Tinshaw
I had a brand new 1 fromCR turbos last Crimbo.... & it's still sitting on me shelf in the garage!!!!!!!!!!!!
Old Feb 7, 2015 | 08:35 AM
Cossy Mike's Avatar
Cossy Mike
Turbo Technics do them but will have Turbo technics on the housing not Garrett.
I'd go T35 at the least these days.
I went for a new sge1 hybrid TT T3, worst decision of my life, another Ł400 and I could of had a T38/T4
Old Feb 7, 2015 | 08:51 AM
Marc sierra
Do you mean TT will have a T34? A T35 is the same as a T34.63 right?
Old Feb 7, 2015 | 08:59 AM
Marc sierra
So at what boost wouldn't it surge? I would run a lower boost for now anyway as the big boost will kill the gearbox.
Old Feb 7, 2015 | 09:54 AM
scoooby slayer
cossierich ran one at 453 hp on a stock port head with just a bd14 inlet cam at iirc 30 psi.
I would think you should be ok at 20 psi, I ran a t4 on a stock port head with bd14 inlet and could run 22 psi before surge was an issue.
ask stu or tony if he could write a chip for just 20 psi across the board, that's what I would do they are so much more responsive roller bearing turbos and a gt30 with the adaptor rear housing will be a simple bolt on affair
tbh if I was you id want it live mapped anyway to get the best out of it, any off the shelf will be a compromise it has to be on the safe side imo.
Old Feb 7, 2015 | 01:04 PM
Marc sierra
But if the GT3071 is less responsive than a T34.63 and I would limit the boost, what's the point of having the GT3071? I'm Stu would be able to do a safe chip, but it's probably less optimal than the T34.48 chip, as that has been done many many times.
I know a live map would be best, but I'm from Holland so that isn't easy. There are a few people here who can map the Weber management, but none of them do the closed loop fuel control that I really want to have.
So I still believe a closed loop, off the shelf chip for a T34 is my best and easiest option. It's a bit of a shame, because I know the GT3071 live mapped and running full boost would be much nicer. But I'm coming from the standard T3, which is only running about 1.2 bar since it doesn't have a 360 degree bearing, so going to a T34 that is able to run full boost should be quite an improvement already.
Old Feb 7, 2015 | 04:39 PM
Bart's Avatar
Bart
We can check the gt3071 chip on the dyno and if necesary let msd change the chip, i told you before Marc.
Old Feb 7, 2015 | 05:15 PM
scoooby slayer
its entirely upto you mate im just pointing out the option I would take.
and I don't believe for 1 second that a gt3071r is less responsive than a t34 0.63.
ive run a gt40 on a 2.6 at over 700 hp and it was more responsive than my old 500 hp yb on a t4, if its available roller bearing I would want it, if you want maximum response go with the smallest turbine housing you can get which is 0.63 I believe, or find a t34 and just fit it just seems a waste to me as you've got to spend anyway so may aswell upgrade while your replaecing it.
Old Feb 7, 2015 | 07:13 PM
2Litre's Avatar
2Litre
I run a gt2871r with .48 housing really great unit only run 20psi but gets there by 3,400rpm starts coming on boost @ 2700 rpm. totally standard internals and engine needs a rebuild.
Don't know what max bhp is at 20psi cos not Dyno'd .
Cheers. T
Old Feb 8, 2015 | 09:23 AM
Marc sierra
Decisions, decisions...
So would an air injector kit solve all the issues with possible surge?
I still wonder what has a smaller boost threshold, the T34 or the GT3071r (Cosworth turbine housing is 0.72). Some say the T34, others say the GT.
Old Feb 8, 2015 | 11:19 AM
MARCOSWORTH
Try CR Turbo, they converted my T34.48 to T38.63
Old Feb 9, 2015 | 07:54 PM
Marc sierra
So what's a T35? I thought that's just a T34.63...
Old Feb 9, 2015 | 08:16 PM
fatboy billy's Avatar
fatboy billy
Had a t34.48 delivered from cr turbos this week
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
