Aluminuim thickness for header tanks and fuel tank?
Need some guidance on the gauge to use for an aluminium header tank and also for a fuel tank?
Many thanks in advance
I chose 2mm as it's fairly easy....even I can manage it LOL
But 3mm would be even easier again, I think 4mm would be excessive though.
Going thicker makes welding easier, but cutting and shaping a bit harder.
Thanks for the recommendations for gauge to be used. I can't alu weld so the welding side with be outsourced, I will be order some sheet and be cutting and shaping the piece to suit some designs I have.
