Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Hydraulic lifters and shims - help with shims!
Old Feb 3, 2015 | 02:25 PM
grishenko45's Avatar
grishenko45
Default Hydraulic lifters and shims - help with shims!
i'm replacing a few lifters in my mk5 fiesta 1.25 zetec. there's only one type of lifter to replace....but there are loads of different shims i could order depending on size...
i checked all the clearances before i took everything apart and they were within the fords cold tolerances. i didn't check them warm, but i used an automotive stethoscope to find which area the tapping was coming from. it was terrible - i had to stop driving it as it was too bad.
do i need to replace the shims too? if i need to order shims too, how do i work out what sizes to order?
thanks
Old Feb 3, 2015 | 07:03 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
You'll have to start from scratch with the shims. If you were just setting the gaps, you would measure the gap, take the shim out, read off the thickness and then get the appropriate thickness of new shim. If the gap was too big, you'd fit a thicker shim, it it was too small, you'd fit a thinner shim. Best be would probably be to fit the new lifter with your thinnest existing shim and then measure the gap. You could then calculate the thickness required to go with the new lifter.
Old Feb 4, 2015 | 08:37 AM
grishenko45
so all lifters are slightly different sizes? what if i put the old shims back it then check the gap and it's fine?
Old Feb 4, 2015 | 11:12 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
The lifters, cam lobes and valve stems all wear over time, that's why they need adjusting. You could find that some or all of them are OK or at the very least you may be able to re-use some in other positions. You'll just have to fit them and check. Hydraulic lifters don't normally have shims though as they self adjust. Only the solid lifters need shims.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
grishenko45
Sep 9, 2015 12:58 PM
