would a 3 dr t3 with a500 cooler= lag
Pretty sure i,m right in saying if running high boost and the little t3 is spinning its nuts off then it will produce a fair bit of heat and warrant a better cooler. Personally I would take more lag for cooler charge temps.
Last year I changed my 4x4 cooler to the RS500 style cooler and I noticed the lag increased noticebly. It's quite logical though, the volume to pressurize is a lot more, so hence it takes longer.
cheers pete ,im presentley working on something else lol
only stage one so should be fine
cheers marc , thought the same but if its not too bad it can stay as is lol
There is a reasonably noticable difference between a std 2wd cooler and a RS500 style one when using a std T3. The response and lag is better with the 2wd cooler, so I'd say better to stick with the std cooler as long as you are'nt running more than around 20psi.
Obviously if you are running the T3 very hard, the charge temps can get quite high with the 2wd item so an Rs500 item would be better in that instance, but personally Id rather have the better response of the 2wd cooler and little lower boost. Overall more pleasant to drive.
Mine had the standard t3 and cooler running greens when i bought the car. One of the first mods i did was change to a 500 style cooler.
I have dyno printouts from before and after done on the same rollers but obviously on different days and it gained 25lb/ft of torque, power stayed the same.
Didn't really notice it having more lag?
If you don't want the 500 cooler definitely use a 4x4 over the tiny 2wd
cheers for the info karl ,stage one 280 will be the max put through the car.
thanks for the offer mate
,i have one here to try if needed Mine had the standard t3 and cooler running greens when i bought the car. One of the first mods i did was change to a 500 style cooler.
thanks for the info ,25lb/ft was a nice bonus with the 500 cooler
