broken locking wheel nut D:
Old Jan 30, 2015 | 12:10 PM
vrum-tss's Avatar
vrum-tss
noob
Unhappy broken locking wheel nut D:
hi guys, new to the forum and just wondering if anyone could give me any advice.. title is the issue. ive tried an erwin socket (erwin?.. irwin? whatever it is) with absolutely no luck. the things so far gone theres nothing to bite on becuase all thats left is practically a semi-circle.
i dont want to risk a hammer and chisel for fear of damaging my alloys unless there is absolutely no other option, any ideas would be great thankyou!
p.s dont ask why there is two locking nuts on each wheel.. previous owner.
i just want a set of four standards on after this episode.
(i know my alloys need a refurb, they were bought like this so no bad driver comments please.)
Old Jan 30, 2015 | 12:36 PM
STeve's Avatar
Super Moderator
look like you may need to have a bolt welded onto what left to remove
Old Jan 30, 2015 | 12:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
12 point socket that won't quite go over and force it on with a hammer.
Then undo it, use a cross brace though so it won't twist off again.
Old Jan 30, 2015 | 04:59 PM
neil andeRSon's Avatar
neil andeRSon
I used a 20 or 21 mm socket the above way.
Old Jan 30, 2015 | 05:04 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
where in lancashire are you at?
i could get that off in minutes i reckon.
Old Jan 30, 2015 | 06:17 PM
Oranoco's Avatar
Oranoco
That's been cunted on with an airgun. Lazy bloody tyre fitters.
Old Jan 30, 2015 | 06:24 PM
RB26DETT's Avatar
RB26DETT
Just weld a nut to it, I had to do that on a BMW.
Old Jan 30, 2015 | 06:36 PM
turbolee's Avatar
turbolee
as said above smack a socket on and it will come off easy
Old Jan 30, 2015 | 07:02 PM
Cossy Mike's Avatar
Cossy Mike
https://www.machinemart.co.uk/shop/p...C=GS-040223291
I used these when my key broke, got all 4 off within the hour. The hardest part was getting the tool off the bolt after it was removed.
However looking at the pics, your kind of stuck. If all else fails and your going to damage the wheel I would be looking to grind off the back of the wheel stud and smack the whole thing through the front
Old Jan 30, 2015 | 08:13 PM
LewisT's Avatar
LewisT
Try a bit harder got that one off with an irwin and its about as fooked as yours did have to fairly mash it on hard to get it bite
botters's Avatar
botters
competant bodger
weld a short half inch extension on and undo with a breaker bar i do this on alllock nuts now no damage to the wheel and takes less than 5 minutes
Old Jan 30, 2015 | 08:43 PM
cossynut2's Avatar
cossynut2
10 Year Member
I had to get a butchered one off my Daughters car and did the same thing. I had to really force the socket over it with a lump hammer but it gripped and undid fine with no damage to the thread or wheel.
Old Feb 1, 2015 | 10:59 AM
vrum-tss's Avatar
vrum-tss
noob
jesus guys thanks i didnt expect so much help! ill have another bash at the irwin and if no luck ill weld a nut onto it, but yeah i think its been tightened on with an airgun.
problem is i have another 7 if thats the case.
xr2wishy ill p.m you if you wana have a go at it i would appreciate it!
Old Feb 1, 2015 | 02:36 PM
cossynut2's Avatar
cossynut2
10 Year Member
Hope you can get them off ok. If you have nice alloys I would still get a new set of locking wheel nuts , just make sure you keep the socket somewhere safe and you wont have the same problem again.
Old Feb 1, 2015 | 04:54 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
You could always nip down to your local Ford dealer and ask them to remove them as they should have a master set.
Might cost a few quid but it would save a lot of buggering about
Assuming they are Ford lockers of course
Old Feb 1, 2015 | 09:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Looks like a mcguard locker, as said its either a 20 or 21mm socket that needs smashing on its been many years since i have had to remove some.
Good luck
Old Feb 1, 2015 | 10:11 PM
scoooby slayer's Avatar
scoooby slayer
Lots of ways of doing it, a smashed on socket has always done me bar once and I had to weld to it.
Old Feb 1, 2015 | 10:50 PM
botters's Avatar
botters
competant bodger
if you had listened to my advice they would all be off now lol! the longest bit is cutting the extension back off the nut when you get them off but even that only takes seconds with an angle grinder
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
IanC
Sep 5, 2015 09:38 PM
