Idle problem Focus RS mk1
Old Jan 29, 2015 | 06:17 AM
LefkadaRS's Avatar
LefkadaRS
Default Idle problem Focus RS mk1
Hello, once and a while when i start my rs it doesn't idle right or it cuts out.Solutions?
Old Jan 30, 2015 | 09:31 AM
RSRick3290's Avatar
RSRick3290
ICV, its a pig of a job as its very difficult to access most people take the inlet off as its easier
Old Feb 9, 2015 | 07:20 PM
Ally Young S1's Avatar
Ally Young S1
Try this first - buy a can of carb cleaner and take of the throttle housing and top boost hose off. Carefully with a wipe clean out as best you can all the carbon (make sure to be extra delicate with the throttle flap). Then spray a liberal amount down down into the inlet and spray and coat everything inside. Leave for an hour or so and then start it up, might be a bit of white smoke as it burns all the carb cleaner off.
Worked for me and all for about a £5
Old Mar 1, 2015 | 07:28 AM
LefkadaRS's Avatar
LefkadaRS
Thanks for the info...Is it possible to tell me the exact location of the ICV?If you can a pic?I want to change it myself.
Old Mar 1, 2015 | 10:09 AM
Fezman1's Avatar
Fezman1
I had the same symptoms. ...was worse when less thank half a tank.
My fuel pump was on the way out. (a common fault)
A dw65 later and she starts on the button every time. regardless of fuel level.
Old Mar 16, 2015 | 10:25 PM
nigs's Avatar
nigs
had the same problem with mine and tried the carb cleaner worked a treat
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
Zoggon
Aug 10, 2015 10:39 AM
