Mondeo 1.8 MK3 2005 Problems
Old Jan 26, 2015 | 06:50 PM
Philss_99's Avatar
Philss_99
Default Mondeo 1.8 MK3 2005 Problems
Evening. Newbie here ( 1st post ) and in need of some help.
Been a Renault owner for the last 10 years but after a Cambelt failure I have decided no more money is going to be spent on it.
So I bought myself a Mondeo 1.8 MK3 2005, A car I have always liked and was within my budget.
Anyway picked car up on Saturday and having nothing but problems. Getting grief of the Wife saying I have bought a bad one. I am not going to be beat by this car so in need of some help / advice Please.
Faults found are as follows :-
Lights - Passenger side head lights, No side light and Dip beam. Main beam fine, Indicators fine. Changed bulbs - still not working. Checked fuses - everything looks in order - still no lights. ( Earth ? )
Cutting out - When dropping gears or slowing down to nearly a stop, car cuts out. ( IACV ? )
Engine Idle - Noticed car revs increase on their own.
Once I get these bits sorted I'm going to book a full service.
Also ... silly question as i'm a little confused. Are IACV & ISCV the same thing or different units ? I'm thinking these are the cause of the problems for the idling & cutting out..
Any advise / help is more than welcome.
Old Jan 26, 2015 | 07:53 PM
Oranoco's Avatar
Oranoco
Evening, welcome aboard the good ship Pf
We all have some dark secrets in our closets.
Picked a Mk 3 Mondeo LX this week myself
If it was a garage sale return it and it's down to them to sort.
Find the headlamp relays and try swapping them over to see if the fault swaps side. Also worth getting in there with a multimeter and checking what you have at the plug side. If you have power at the plug the headlamp unit may be duff itself.
Not sure on that one
PCV pipe under the inlet manifold may have a hole or be split, this can cause those symptoms
Good plan
Pretty much from memory. See comment above re PCV.
Old Jan 26, 2015 | 08:10 PM
Philss_99's Avatar
Philss_99
Many Thanks for your reply.
Regarding the below :-
Are the relays in the fuse box under the bonnet or behind the glove box ?
Old Jan 27, 2015 | 01:30 PM
Oranoco's Avatar
Oranoco
Bugger know's not had mine long enough to break it yet
If yours is an LX model (facelift >04) it's worth sticking your head under the glove box as you are likely to find bulb holders for footwell lighting, pop a 501 bulb in (and under the steering column).
Old Jan 31, 2015 | 05:40 PM
Philss_99's Avatar
Philss_99
Update ....
Lights sorted. Bulbs I bought from local garage were all duff. Auto electrician was scratching his head for an hour before he said pass me the bulbs and found they were rubbish.
Need some help with the cutting out and engine idle.
Thanks in advance.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
