Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
blown engine help!
Old Jan 24, 2015 | 07:00 PM
dizzy13's Avatar
dizzy13
Default blown engine help!
Hi new to the the forum. I have bought a 1.6 2006 focus and the engine has blown. (Con rod shot through the sump). Its the hxda engine and have been searching for one to swap. But there's quite a few... basically will a hxdb hxja fit straight in aswell? Any help would be appreciated cheers.
dizzy13
Old Jan 24, 2015 | 07:31 PM
dizzy13's Avatar
dizzy13
Anybody???
Old Jan 25, 2015 | 02:30 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
If yours is VVT model then you will need a VVT engine. If its a bog standard 1.6 then put any 1.6 focus engine in just swap all your bits off your old engine. Engine code is irrelevant imo done loads over the years never had an issue.
Old Jan 25, 2015 | 02:34 PM
dizzy13's Avatar
dizzy13
Cool so even the newer hxdb should fit then. Cheers
JoeyBoyden
20
Aug 22, 2015 03:23 PM
