Clearance
Old Jan 23, 2015 | 06:54 PM
2Litre's Avatar
2Litre
Default Clearance
Hi all, I a m currently rebuilding my YB engine. and have been told that 3thou piston to bore clearance is what I am looking for this I have been told is also true of main bearings along with big end bearings.
Can anyone one confirm this to be correct?
We all know what the manual states and I have been told that @ 9psi standard boost/heat levels this would be correct yet if you were to run a modest 20psi the goalposts do change.
I know how engines work, and require nothing more than an expert engine builder's confirmation on what is stated above, is this a loose setup? at 20psi ? I am currently running a .48 housing running a GT2871R so I will probably have to change the turbo to a GT2860RS so I don't out run the 803 injector period.
Please don't educate me on anything other than I have asked, Bla , Bla Bla. I do not intend on running more than 300bhp don't want longstuding , don't want a metal gasket that requires me to cut my block and head in half.
Thanks very much.
Tim.
Old Jan 23, 2015 | 06:59 PM
Mark Shead's Avatar
Mark Shead
You need to say what pistons you are running.
Mark
Old Jan 23, 2015 | 07:06 PM
2Litre's Avatar
2Litre
Mark, thank you for your time , running 0.50mm 0versize mahle pistons with cutouts from Matt lewis..
Thank you.
Tim.
Old Jan 23, 2015 | 07:11 PM
Mark Shead's Avatar
Mark Shead
Thank you.
Tim.
Standard clearance will be fine.
Mark
Old Jan 23, 2015 | 07:18 PM
2Litre's Avatar
2Litre
Thanks very much.
Tim.
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
155lee
14
Aug 22, 2015 12:15 PM
