anyone with a engine leak tester local to bromley in kent want to earn some ££?
hi guys, i really don't see the point in buying a engine leak tester only to use it once, i want to do a leak test on my golf VR6 to see what is worn to see if the bottom end is ok. These are done with a compressor that forces air into the cylinders. Im located in bromley, kent and willing to pay you for your time
obviously i can come to you if you are not too far as i can only drive short distances.
paceo
Aug 27, 2015 12:45 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Gadget
Aug 13, 2015 08:19 PM
