Focus 1.8 idle rev problem and continuously stalling
Old Jan 17, 2015 | 03:29 PM
Windech's Avatar
Windech
Default Focus 1.8 idle rev problem and continuously stalling
Hi. I've had this problem on and off for a while now, but it's getting to a point where I'm getting annoyed with it.
The car's idle revv counter doesn't seem right, i'm not sure if it's an air problem or a sensor issue.
Whenever I knock the car out of gear and coast to a red light or any stop, the car stalls. The revvs go down to <600, the battery warning light comes on, and stalls. If i'm quick enough i can give the car a touch of gas and it stays running, and the light goes out.
I've just replaced the crankcase vent pipe because that popped the engine management light on a few weeks back. I'm not sure if these 2 issues are related.
A friend of mine mentioned it could be an air intake issue, or there's a problem with a fuel sensor. But i'd rather have the opinion of someone more specialized.
Thanks in advance
P.S Can you dumb down your responses for me
Old Jan 17, 2015 | 03:34 PM
mark826's Avatar
mark826
How old is the focus and is it petrol or diesel?
Old Jan 17, 2015 | 05:48 PM
Windech's Avatar
Windech
1999/2000 and Petrol.
Old Jan 17, 2015 | 06:23 PM
Silver Zetec Turbo's Avatar
Silver Zetec Turbo
Boost Junky
When you say the crank case vent pipe has been replaced was it the one that goes from the right hand corner of the engine (near gearbox bell housing)to the inlet manifold ?
Old Jan 17, 2015 | 07:09 PM
Windech's Avatar
Windech
http://www.ebay.co.uk/itm/New-Genuin...-/360784038582
There was a split in the previous pipe, so i had that fitted.
Old Jan 17, 2015 | 07:47 PM
mark826's Avatar
mark826
Could be an idle speed control valve issue?
Old Jan 17, 2015 | 10:33 PM
Silver Zetec Turbo
Boost Junky
that is the common one that splits causing a fast idle speed . You could try dis connecting your battery for a bit and re connecting to see if that cures ?
Old Jan 18, 2015 | 12:06 AM
Big AL's Avatar
Big AL
Odds on it's the vss, vehicle speed sensor.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
taylora1409
Aug 12, 2015 12:06 PM
