Rev Counter
Old Jan 8, 2015 | 07:32 AM
djmca's Avatar
djmca
Bring back old skool Ford
Default Rev Counter
Hi all,
Can anyone help with this!!!
I am running a 2 litre silvertop on carbs in my 1982 MK3 Escort and using the silver Esc module. I have been trying to wire up the rev counter with no luck. Googled it over and over again and and found wiring diagrams for diodes to connect from the module but I tried this and the car wouldnt even start, just wound over and back fired.
Anyone know how to do this and can tell me in an easy to understand way??
Thanks all!!!
Old Jan 27, 2015 | 12:23 PM
stevieturbo's Avatar
stevieturbo
C**t
What are you using for ignition ?
Old Jan 27, 2015 | 02:54 PM
djmca's Avatar
djmca
Hi mate, Im using the silver ESC module from a late MK4 Escort to control ignition. Plan to go Megajolt or Nodiz in the future but it does the job atm.
Old Jan 27, 2015 | 03:01 PM
stevieturbo
C**t
So does the module not have a rev counter or coil output ?
Old Jan 27, 2015 | 03:28 PM
djmca's Avatar
djmca
It has a green wire which apparently is for the rev counter but it is only reading half revs!
Old Jan 27, 2015 | 03:40 PM
stevieturbo
C**t
So what are you using for an actual trigger for this module ?
You can take the rev counter apart and there might be an adjustable pot to correct it, or you may need to use other means
Old Jan 27, 2015 | 04:51 PM
djmca's Avatar
djmca
Its using the crank sensor to fire the ignition and timing is set by inlet and water temp
Old Jan 27, 2015 | 06:51 PM
stevieturbo
C**t
So it's a modern wasted spark setup going firing into a older rev counter ?
You can get various pulse adjusters, but I'd be taking the rev counter apart first to see if it can be adjsuted
Old Jan 28, 2015 | 11:53 AM
djmca's Avatar
djmca
Yes that sounds right!! Il have a play with the rev counter see if I can sort it, thanks for the help.
Love the Granada by the way, ive been talkin to you a few times at Cultra climb etc.
Are you going to Bishopscourt in March? Mr Purdy is taking the beast apparently!!
Old Jan 28, 2015 | 01:28 PM
stevieturbo
C**t
March is miles away ! lol, no idea, just see how things are near the time
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
