Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
No idle when cold - fly by wire throttle.
Old Dec 30, 2014 | 02:08 PM
graysclassics's Avatar
graysclassics
Default No idle when cold - fly by wire throttle.
Fiesta V, 1.4 16valve. Starts fine, idles ok for a little while, touch the throttle and idle goes to hell. Drives like absolute crap.
When engine warm drives normally. Low mileage car. Changed throttle pedal/TPS and throttle body with absolutely no difference. If you disconnect the battery for a bit it seems to help as if the problem is with the ECU itself which has been changed in the past as the coil pack blew and took the ECU with it. If it had a throttle cable it would be the idle control valve but with the fly by wire system I am now at my wits end.... no faults on diagnostics. Help
p.s. changed the coil pack again and the fuel pump just to eliminate the poor running as described by by daughter but since discovered only has the issue when cold.
I have checked other posts but cannot find the answer so apologies if this has been asked before. Thanks guys.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
TPM961
Jan 15, 2018 10:50 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
