Focus rs gearbox into rs turbo--- speedo?
Old Dec 24, 2014 | 01:53 PM
davidfox280585's Avatar
davidfox280585
Default Focus rs gearbox into rs turbo--- speedo?
Hi all. currently converting my s1 rs turbo to take a focus rs gearbox as the bc/ib5 cannot hold power.
now the issue i have come across is the focus uses electronic speedo, i have been looking at the race technology dash 2 pro but wondered if i can use the standard frs elec drive in the box or if i need to use a universal speedo off a wheel?
what have you guys done with yours?
thanks in advance
Old Dec 24, 2014 | 09:27 PM
studabear's Avatar
studabear
When I go mtx on mine I will use a mondeo mk2 diesel box with cable speedo then hopefully have a lsd fitted into that.
Old Dec 24, 2014 | 10:28 PM
RUBY123's Avatar
RUBY123
i use the focus speed drive on a stack dash no problem
Old Dec 25, 2014 | 08:08 AM
crazycage's Avatar
crazycage
The onIy problem with this is you can't use the focus rs clutch mate fouls the inside of the bell housing .you space the box off the engine to make it fit.
Old Dec 25, 2014 | 11:16 AM
studabear's Avatar
studabear
Cheers for the tip Gary, luckily I've a few spare ib5 boxes to kill off before I go mtx.
I presume it is spaced with a couple of gearbox spacer shims?
Old Dec 25, 2014 | 01:14 PM
davidfox280585
Cheers ruby, yes I've decided focus rs as the gear set are shot penned and fairly robust, hopefully if the frs speedo drive can work with a stack then a tech dash 2 should be fine
Gary, how have you done yours?
Thanks in advance
Old Dec 25, 2014 | 05:51 PM
crazycage's Avatar
crazycage
Thanks in advance
I've got a stack Speedo in my fez turbo and no Speedo in my mk2 drag fez
Old Dec 25, 2014 | 05:53 PM
crazycage's Avatar
crazycage
No I tried one on mine and didn't like it mate was spaced about 8mm so swapped to a focus rs box
Old Dec 25, 2014 | 06:51 PM
studabear's Avatar
studabear
I better sell this box I have then.
Old Dec 25, 2014 | 07:10 PM
davidfox280585
Are you running this off the focus box speedo or using a external sensor on a wheel, I was talking to a lad with a stack in his s2 with frs engine and box and he ran a separate off a wheel
Old Dec 25, 2014 | 07:59 PM
crazycage's Avatar
crazycage
Off the standard sensor in the box
Old Dec 25, 2014 | 08:20 PM
davidfox280585
May need to tap you up for wire colours if you don't mind Gary?
Will get these shafts over your was start of new year there off ready👍
Old Dec 25, 2014 | 08:22 PM
davidfox280585
Most of the time it's 12v Earth and signal feed I've not even looked at how many wires are there tbh
Old Dec 26, 2014 | 10:36 AM
RUBY123's Avatar
RUBY123
yes there is just 3 wires as you say power earth and signal i cant remember if the power is 12 volts or 5 volts though. then all you have to do is find out how many triggers/point per wheel revolution from the focus vss and away you go
Old Dec 27, 2014 | 05:39 PM
davidfox280585
Thanks all, I will look into the voltages and wiring
Many thanks for the replies👍
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
gingeRS
Sep 4, 2015 06:29 PM
