Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
focus 1.8 pin outs for rev counter. I'm fitting omex
Old Dec 20, 2014 | 06:53 PM
mk1 rob's Avatar
mk1 rob
Default focus 1.8 pin outs for rev counter. I'm fitting omex
Hi All, I'm fitting omex management to a 1.8 1998 focus. I need to know which pin on the ecu or back of dash cluster is for the rev counter. Also whether or not the speed sensor can run straight to the cluster without going through the original ecu.
Thanks in advance.
Rob.
Old Jan 31, 2015 | 01:12 PM
rs2000craig's Avatar
rs2000craig
Hi, Did you find this information out? As I need to know this also. Thanks
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
turbobill
Aug 9, 2015 05:21 PM
lockie
Jul 31, 2015 10:03 PM
