Rs turbo front bearing cups
Old Dec 15, 2014 | 02:04 PM
RS 5tu's Avatar
RS 5tu
Default Rs turbo front bearing cups
Is it possible to get new bearing cups for S2 escort front hubs?
Old Dec 15, 2014 | 02:33 PM
haz87's Avatar
haz87
Were available last year when I needed some.
Edit: from Ford
Old Dec 21, 2014 | 08:20 PM
RS 5tu's Avatar
RS 5tu
I managed to get some time to remove the bearing cups from my hubs to see if I can get a part number.
Managed it and if anyone is interested the part number for the bearing cups is 4T-JL68111Z
(Not 100% it will be the same for all escorts)
Old Dec 22, 2014 | 10:08 AM
haz87's Avatar
haz87
Oh i thought you meant the dust seals. Ignore my prev comment then
Old Dec 23, 2014 | 05:57 PM
xrmalin's Avatar
xrmalin
Why would you want the bearing cups on there own ?
Bearings are made as a pair inner & outer so if you match an inner with a different outer the bearings won't last as long as they should do.
Old Dec 23, 2014 | 07:32 PM
RS 5tu's Avatar
RS 5tu
Im replacing the bearing cups due to them being sandblasted by the company that did all my powder coating so they are no good due to them being rough now and not smooth as they should be.
I also have all new bearings already so it will be as new.
Old Dec 23, 2014 | 09:07 PM
studabear's Avatar
studabear
Bearings come with the races or as you describe the cups.
Old Dec 23, 2014 | 09:16 PM
RS 5tu's Avatar
RS 5tu
I have been unable to get any, went on ebay lots of bearing set have them in the picture but after asking the sellers they say they don't come with them.
At least I can get hold of them I was worried I was going to have to buy new hubs and have them coated.
Old Dec 23, 2014 | 09:46 PM
studabear's Avatar
studabear
Currens in clevelys, i've had them off them. Tbh i've never ever seen a taper roller bearing kit where it isn't supplied with the races.
Old Dec 24, 2014 | 08:25 AM
haz87's Avatar
haz87
Same
Old Dec 24, 2014 | 09:06 AM
RS 5tu's Avatar
RS 5tu
maybe the guy didnt understand what i meant.
I have ordered aload of bit inc bearing kits so they will probably come with at least i can get it all built up again.
Old Dec 24, 2014 | 10:33 PM
Chas's Avatar
Chas
What the above said. All taper bearing kits I have bought until this point have come with the bearing cups as well as the taper bearings themselves.
Now here is an interesting question (and a potential hijack!). Do the Escort bearing require pressing in or simply changing like most other taper bearings (i.e with sockets etc.)? I ask as there was a debate not too long ago where certain folk thought that the MkIII/IVs were a press in job only. I initially disagree but OTOH 200NM is alot of torque for a taper bearing which generally require a very slight (well, generally barely any preload) to last any length of time.
3i Jim
Nov 20, 2015 05:12 AM
C2 MAK
Aug 20, 2015 09:46 PM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
