Starter motor grinding on front of fly wheel not engaging s2 turbo
Old Dec 13, 2014 | 06:28 PM
Liamkyle123's Avatar
Liamkyle123
Default Starter motor grinding on front of fly wheel not engaging s2 turbo
I've just done a full fiesta rs turbo conversion with ofab loom, I am having a starter motor issue, I just brought a recon starter which in the ad says its for both fiesta and escort 1,6 turbo, but when I turn the car over it seems that the starter is not engaging you can hear the cog just spinning, then if you carry on for around 10seconds it's starts grinding on the fly wheel? Is this a starter motor problem? Or not enough power going to starter?
Old Dec 13, 2014 | 07:54 PM
3i Jim's Avatar
3i Jim
10 Year Member
Sounds like a dodgey starter.
Old Dec 13, 2014 | 08:04 PM
studabear's Avatar
studabear
Is the gearbox spacer fitted between engine and box? Is the ring gear on flywheel in good order?
JoeyBoyden
Jan 4, 2024 02:36 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
fatboy billy
Aug 3, 2015 08:34 AM
vdubo7
Aug 2, 2015 08:17 PM
