focus st170 clunk / thud possible steering rack
Old Dec 4, 2014 | 06:34 PM
syko2005's Avatar
syko2005
burning oil
Default focus st170 clunk / thud possible steering rack
my st170 has developed a clunk, and what feels like, some resistance when turning the steering wheel from central, to left.
I've recently changed the wheels from stock, to a aftermarket set which are the same size, but a slightly different offset. The problem seems to have appeared since fitting the wheels. Perhaps this has just highlighted a issue.
Ive done plenty off googling regarding the above problem, and all the information points to the rack being worn. However i thought id ask on here first.
One thing I have noticed is the power steering fluid is black, im going to flush it tomorrow, although im not hopeful it will cure the problem.
If it turns out to be the rack at fault, how safe is the vehicle to drive. Is it likely to completely fail?
Thanks
Old Dec 4, 2014 | 07:11 PM
3i Jim's Avatar
3i Jim
10 Year Member
Sounds like the rack but having black power steering fluid isn't going to help. If the rack is knackered you really should change it. I'm sure a complete fail is unlikely but it's not worth the risk.
Old Dec 4, 2014 | 07:36 PM
syko2005's Avatar
syko2005
burning oil
Cheers for the reply. Il get the fluid changed tomorrow, i was hoping it would be okay to drive until im off work, over Xmas.
Old Dec 4, 2014 | 08:55 PM
Colin_P's Avatar
Colin_P
I had this and it was the rack.
I eliminated everything else first, new wishbones etc.
While I was eliminating things I was still driving it and did so for about a month.
I wouldn't bother flushing as it is likely to be a waste of time and money.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Tank Mike
Sep 10, 2015 07:56 AM
