2ltr pinto turbo inj 205 block
Old Mar 31, 2005 | 04:51 PM
anglia105e hinson's Avatar
anglia105e hinson
Default 2ltr pinto turbo inj 205 block
yo i'm currently carrying out a turbo conversion on a 2ltr pinto injection it uses the 205 block. the problem is i need an oil drain tube (from turbo)which is threaded into the block then passes through the bottom of the block into the sump. does any one know where i can get hold of one. any help would be great.
also what is the miniuim size discs i can use with rs focus brembo calipers
Old Mar 31, 2005 | 07:29 PM
richm's Avatar
richm
any chance you could make a 2wd Cosworth Sump fit? you get a turbo oil return directly into the sump then, and an alloy sump .
Old Apr 1, 2005 | 06:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i would also use a 2wd cossie sump. will fit straight on. use proper cossie gaskets though, or it will leak.
big_Rad
Sep 15, 2017 09:36 AM
James Porter
Oct 28, 2015 12:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
cossiedean84
37
Sep 2, 2015 10:19 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
