Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Heating/Cooling Directon Knob MK6 2006
Old Nov 26, 2014 | 04:27 PM
jonnycool's Avatar
jonnycool
Default Heating/Cooling Directon Knob MK6 2006
Hi All,
Having a small issue with my Heating/Cooling Driecton knob it just spins around so i cannot direct the air flow?
Any help is much appreciated.
Thanks
JON
Old Nov 27, 2014 | 09:51 AM
Spike Nutter's Avatar
Spike Nutter
Hi Jon
Have you removed the front fascia recently by any chance?
The control clips into the dial at the back of the knob, it goes in only one way to make it work, but you can fit it so it sits in but does sod all which I did a few times. Have a watch of this video which shows you how to remove the fascia and fit it back in
Hope this helps
Old Nov 27, 2014 | 05:29 PM
jonnycool's Avatar
jonnycool
Haven't removed anything and wouldn't know how.
Managed to turn the to the direction that i wanted this morning but after 1 or 2 twists its just gets stuck again. Its as if its rounded off its also worse when its warm. If i leave it over night i can get one twist in then after that its game over.
rex647
Mar 6, 2022 06:20 AM
Chopshop85
Oct 22, 2015 09:26 PM
Vacuman
Sep 22, 2015 12:09 PM
Flatlinedan
Sep 18, 2015 12:41 PM
