type 9 gearbox mount which one?
Old Nov 24, 2014 | 07:31 PM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default type 9 gearbox mount which one?
Hi, Could somebody please tell me which gearbox mount i need for the type 9 gearbox. I have a mk1 3 door sierra 1.6 base model and at the point of mounting it up and the mount i have came from a 1.8 cvh sierra but its far to wide as the mounting holes on the 1.6 are narrower and up inside the tunnel. Thanks in advance
Old Nov 24, 2014 | 07:32 PM
wheelwizardrefurbs
also i know that the floor pan can be drilled but dont really want to go down that route. hoping there is a direct fit?
Old Nov 25, 2014 | 07:08 AM
wheelwizardrefurbs
Up ttt
Old Nov 25, 2014 | 10:59 AM
mk22door's Avatar
mk22door
Fart of the Purniture
The tunnel on the early Sierra's is different, your going to have to fabricate something to make it fit or modify the tunnel.
Old Nov 25, 2014 | 11:02 AM
mk22door's Avatar
mk22door
Taken from another forum
Originally Posted by Stixy
September 84 will have the narrow tunnel without the sliding mounts , but unless your going A4ld or 4x4 shouldnt it be a problem , Type 9 will fit straight in MT75 from memory will need blocks between the g/box mount and the brackets on floor .
I will see if i have any pictures but its been about 12 years since i put an MT75 in a mk1 ( for sombody else ) and it was pre digi camera days so may take a while
So I'm not sure why yours doesn't fit because this guy knows his Sierra's.
TPM961
Jan 15, 2018 10:50 AM
yatta
May 21, 2016 10:31 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Adam Graham
Sep 6, 2015 06:04 AM
