Sierra Dashboard
Old Nov 20, 2014 | 07:21 PM
Walsh's Avatar
Walsh
Default Sierra Dashboard
Can someone tell me if it's possible to put the mondeo's dashboard in sierra? Mondeo from 97-98 year make. Also with mondeo door panels... Tell me your expirience if you did something similar.
Old Nov 30, 2014 | 03:24 PM
Jack and the Beanstalk's Avatar
Hey Walsh.
I'm also researching to do a non sierra/sapphire dasboard install. Only one I've come across on the net so far is somone used a ford scorpio or late granda dash. From what I could see is that he had to hack it to make it fit.
I too also like the mondeo dash with steering configuration. I want to know if I could use the mondeo steering config with cruize control and mount it with a later spec sierra / sapphire dash.
This is also a longshot, if the mondeo dash and steering comes with airbags and could be modified to fit the sierra/sapphire, could this also be a createbable safety factor. Imagine a sierra with safety airbags. First of its kind.
Hope your thread inspires others to give some good ideas.
Old Dec 7, 2014 | 02:47 PM
Walsh I know this is your topic, but do you other enthusiasts know if a Sierra P100 later type dash would fit into a sierra sapphire saloon?
I found pictures of the P100 with the different dash ill try and post them up, i just cant remeber which site I pulled them off of.
Old Dec 7, 2014 | 08:05 PM
Walsh's Avatar
Walsh
http://i.wheelsage.org/pictures/ford...o_sedan_95.jpg This is the dash that I want to fit in Sierra. But I don't know if it can fit. No need for waisting money if someone knows the answer. As for the P100, post some pictures. If it's standard Sierra dash it can fit.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
