Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Koni suspension kit
Old Nov 20, 2014 | 03:50 PM
Prickly_buzz's Avatar
Prickly_buzz
Default Koni suspension kit
Whats peoples thoughts on these? I cant seem to find any reviews anywhere.
Ive always jnown koni to be a good quailty make and they are now using H&R springs so i rekon should be a good set up.
Got a 1.6 2003 focus
Old Nov 20, 2014 | 05:51 PM
t230's Avatar
t230
id go for h&r. ive heard GAZ transforms your car handling....
Old Nov 20, 2014 | 06:18 PM
Prickly_buzz
I have heard GAZ are top notch but im looking around £300
The other option was bilstein B4 shocks and eibach springs, the eibachs i know are good.
Originally looked into coilovers but anything sub £500 was getting hit and miss reviews and i believe you get what you pay for!
Old Nov 22, 2014 | 09:11 PM
Prickly_buzz
Unless anyone can suggest another set up which they can recommend?.....
Old Nov 22, 2014 | 10:24 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
You've already hit the nail on the head - you get what you pay for.
Had Koni coilovers on mine, found them to be very good, eventually all the adjusters seized up but that's probably as much because I didn't maintain them enough than because of a problem with the suspension.
I believe Koni shocks can still be overhauled/rebuilt as well, so a better option if you plan on keeping them a while.
I've just replaced mine with Bilstein dampers and Eibach springs.
Old Nov 22, 2014 | 10:28 PM
Prickly_buzz
Oh ok, which bilsteins did you go for, the B4's seem very reasonable but in not sure if these are any good. One idea I had was to go with these bilstein shocks and eibach springs.
Old Dec 4, 2014 | 02:06 PM
t230's Avatar
t230
Demon tweekes have bilstein shocks for 34 plus vat - couple them with some decent springs!
Old Dec 16, 2014 | 08:38 AM
Prickly_buzz
Seem like a good deal, I know the B4s are entry bilsteins and probably not any 'firmer' than standard but tbh im not looking for track car handling, just want it slightly stiffer and lower, as the car handles great in standard form!
Whats the best springs to go for? I know the eibachs are highly rated however ive been looking at some H&Rs as they lower slightly more, anyone had any experience with these?
Old Aug 24, 2019 | 04:27 PM
focus1.6's Avatar
focus1.6
a good compromise is to have yours rebuilt. they cost less than a new one with a fixed setting like the koni street. with the adjustable kones I had problems that lost oil from the valve on the domes and nobody was able to reconstruct them bilstein instead they seem to be more resistant and above all they use the standard pieces that are easily found to reconstruct them.
the b4 are the same as the standard ones. if you want the car a little more rigid spending as much as a b4 you have to rebuild an original. so you can also decide if you want to shorten the stem or not (recommended if you want to use lower springs).
I've always enjoyed myself with prokit
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
