Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Twisted wire wheels
Old Nov 18, 2014 | 08:15 PM
Gaz 88's Avatar
Gaz 88
Default Twisted wire wheels
Do they make these for 5 inch grinders? Can only seem to find them with a thread for an arbour?
Old Nov 18, 2014 | 08:34 PM
liammcl's Avatar
liammcl
Search for twist cup brush. Just make sure you get roughly 80mm diameter or smaller as any bigger will be a bit lively to hold on to.
http://www.ebay.co.uk/itm/like/19053...13=80&ff14=108
Old Nov 18, 2014 | 08:51 PM
Gaz 88's Avatar
Gaz 88
Cheers pal, but how will that go onto a standard grinder with the thread? I need one with just a hole don't i?
Old Nov 18, 2014 | 09:39 PM
liammcl's Avatar
liammcl
The 2 part bit that holds a grinding disc on is removed along with the guard. Then the wire wheel screws onto the spindle
Old Nov 18, 2014 | 09:46 PM
RichieST's Avatar
RichieST
As above, they will fit on a standard grinder. don't forget face protection I have seen a piece of wire come off one of these and get inbedded in someone's face!
Old Nov 23, 2014 | 02:16 AM
stuboy's Avatar
stuboy
or wear shorts..... learnt thats one
whizzisat114
Sep 1, 2015 02:19 PM
YODI
Aug 30, 2015 01:12 PM
jdsjojo
Aug 26, 2015 10:09 PM
muz
Aug 16, 2015 12:57 PM
