What head on sierra 4x4 front propshaft flange bolts
Old Nov 16, 2014 | 02:37 AM
4x4kiwi's Avatar
4x4kiwi
Default What head on sierra 4x4 front propshaft flange bolts
Trying to find the correct tool to remove the flange bolts at front of front propshaft where it attaches to diff. Manual says they are torx but I have to say they look like normal allen key but none of my allen keys or torx bits seen to fit nice and tightly. If someone could confirm what they should be I will have another go. Don't want to round them off by using the wrong bit. Thanks David.
Old Nov 16, 2014 | 08:08 AM
cozzzzy power's Avatar
cozzzzy power
Default prop bolts
hi mate, mine had allen head bolts in, 6mm allen key I think, but mine round off trying to undo them so ended up undoing them with hammer n chisel, got new ones from fords they add 13mm heads, any bolts will do as long as there hi tensile 12.9, hope this helps
Old Nov 16, 2014 | 08:48 AM
4x4kiwi's Avatar
4x4kiwi
Thanks or the reply. 6mm is the closest I could find but it did feel like it didn't fit quite right and would probably spin in the head - hence the question. Hoping not to destroy them getting out so I can re use them.
Old Nov 16, 2014 | 09:18 AM
cossie330's Avatar
cossie330
Hi, mine were 6mm allen key as well
Old Nov 16, 2014 | 11:52 AM
Paul_RS's Avatar
Paul_RS
6mm allen head - Buy new ones before you take yours off - They usually bugger up lol
Vincereese
Aug 15, 2015 06:24 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
