do you run a......
... Turbo timer????
if so which one do you have?
Pros/Cons?
did you fit it yourself or not?
do you have any advice regarding them? please post here
Pros/Cons?
an see my self getting paranoid about the turbo cooling. with a TT at lease i would feel like it was getting the correct treatment after being driven
blitz turbo timer.
PROS: Acts as boost gauge. Also keeps peak boost: which you can reset at any time. Don't have to worry about running off boost for a short time before you switch off (if that's how you want to drive: I personally don't and norm run off boost before my destiniation). Looks cool when you get out of your car with the engine running, then it shuts itself off & locks the doors as you walk away.
CONS: People who tell you that you haven't turned your car off.
Fitted by car electrician. Don't really do electrics (bar stereos) so rather pay someone who knows what they are doing to fit it.
There are lots of different types & manufacturers who deal wit these. They all have slightly different specs, so pick one which you think will be most useful to you: 1/4 mile times, 0-60 capability, boost guage with peak hold, lap times.
Just don't thrash the car for the last 2 miles before you get home then leave it for a minute before you switch off....
Plus you invalidate your insurance by having one fitted as it bypassed the immobiliser circuits to keep it running and break the law by leaving a running engine unattended.....
It may by-pass the immobiliser, but once it counts down, the engine stops. A thief cannot drive it away. The timer should always be fitted into the handbrake controls so that as soon as anyone (thief/small child) releases the h/brake to move the car, the timer cuts out & the car stops.
It is illegal to leave an engine running unattended regarldess.....
[Ok then, SOME insurance companies will invalidate your insurance...
Seems to be about a dozen companies now that will touch modified cars..the others aren't interested at all...or charge well over the odds for it.
Eigdoog
Sep 13, 2015 05:46 AM
