Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Speedo problem
Old Nov 14, 2014 | 03:09 PM
zsdom's Avatar
zsdom
Default Speedo problem
Hi all
I have an issue with my fiesta, it had a 1.7 swap which was working like a dream, it was then swapped for a cammed 1.7, the engine was the only thing changed, ECU, loom & gearbox were all the items I already had on the car however since its all been put back together the speedo isnt working, I've swapped the sensor over to no avail the clock test shows all needles working fine but no reading whilst moving, does anyone have any ideas of what else to look for to see what could be causing this?
DAZZER
Sep 30, 2015 08:43 PM
cossie brad
Sep 29, 2015 02:38 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
