fuel lines cosworth
Old Nov 4, 2014 | 07:50 PM
sharpercarper123's Avatar
sharpercarper123
Default fuel lines cosworth
i want to replace the plasic fuel pipe on my saph that goes from the banjo on the fuel filter to the metal fuel line but how do u connect the new braided hose to the metal fuel line just concerned about it coming off under pressure cheers steve
Old Nov 4, 2014 | 08:13 PM
cozzy jeff's Avatar
cozzy jeff
To do it properly you'll have to remove the fuel line and have an an6 fitting welded or brazed onto it.
Old Nov 4, 2014 | 08:23 PM
sharpercarper123
cheers where do i get a an6 fitting from?
Old Nov 4, 2014 | 08:42 PM
anglia105e hinson's Avatar
anglia105e hinson
Or use a compression fitting with an-6 on the end
http://pages.ebay.com/link/?nav=item...d=150672198035
AN -6 (AN6) STRAIGHT Female To 5/16" (8mm) Tube / Pipe / Hardline Adapter BLACK
One of these, I use these from pump to hardline then hard line to fuel rail and regulator .
They are perfect
Old Nov 4, 2014 | 08:43 PM
anglia105e hinson
You can get them with male or female an-6 ends
Old Nov 4, 2014 | 08:47 PM
cozzy jeff's Avatar
cozzy jeff
http://www.ebay.co.uk/itm/AN-6-AN6-M...item27e633ede0
then of course you'll need a fitting for the end and a fitting and for the fuel filter plus the braided hose itself.
Old Nov 4, 2014 | 08:48 PM
sharpercarper123
nice 1 i will get 1 puchased
Old Nov 4, 2014 | 08:51 PM
sharpercarper123
will putting a 8mm braided hose be ok just sliding on a 8 mm banjo for the filter end
Old Nov 5, 2014 | 05:26 AM
cozzy jeff's Avatar
cozzy jeff
Torques on the link above does a fitting to fit the filter.
3doorcozmess
Aug 21, 2015 11:17 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Aug 14, 2015 07:29 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
