when have to use low comp piston
Old Nov 4, 2014 | 05:39 PM
luxembourgrst's Avatar
luxembourgrst
Default when have to use low comp piston
hy I want to know at what kind bhp or and how mutch turbo boost psi
it s a good idea to have low compression piston on our escort rst ?
on the 1.6 cvh is it good to have low comp piston
thanks
Old Nov 4, 2014 | 06:23 PM
russ rs's Avatar
russ rs
Stay standard comp
Old Nov 5, 2014 | 04:59 AM
luxembourgrst
Looking for 230 bhp. Standard piston are better at this stage bhp then low comp ? And run like more then 18 psi
Old Nov 5, 2014 | 12:00 PM
russ rs's Avatar
russ rs
Standard up to 300ish
Old Nov 5, 2014 | 12:20 PM
russ rs's Avatar
russ rs
[QUOTE="russ rs;6534683"]Standard up to 300
Old Nov 5, 2014 | 01:34 PM
luxembourgrst
Yes i know cristian did it. But whats about knocking. At 18 psi or more
Low comp piston are helpfull to us with wich kind of spec?
Old Nov 9, 2014 | 10:38 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Boost is relative to your engines VE so talking about running X amount of boost is irrelevant, 18psi on one engine will make 180bhp but on another 230bhp for example.
For 230bhp standard CR is fine though.
Old Nov 22, 2014 | 08:57 AM
luxembourgrst
I got my piston Wössner with standar Comp 8.3:1
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
Tank Mike
Sep 26, 2015 08:07 AM
