2WD Cosworth Engine
Old Nov 4, 2014 | 02:48 PM
Cossie-26's Avatar
Cossie-26
Default 2WD Cosworth Engine
For Sale is my 205 Block cosworth engine that i recently removed from my sapphire cosworth.
The engine has only done 3000 miles but at the time of the rebuild i never got round to having the outside "tarted up" so to speak.
I have had the rocker cover powder coated and machined, the exhaust manifold cleaned.
All mounts brackets pulleys etc have been painted or powder coated. Nuts and Bolts have been Zinc coated.
I have fitted a brand new cambelt and tensioner pulley with wrc lock nut for buyers piece of mind.
The engine itself was rebuilt by a reputable engine builder down here in Portsmouth.
All parts mentioned were fitted at time of rebuild so have done around 3000 miles also.
I had the block honed and pistons refitted with new oversized rings.
ACL Race bearings throughout.
ARP Conrod bolts.
Cosworth HP Oil pump.
Victor reinz uprated head gasket.
New Cosworth head bolts.
2wd Head fully reconditioned.
Bosch 90Amp Alternator (500 miles)
Inlet manifold stripped and cleaned
Motorsport HT Leads
3 bar map sensor
New Coolant sensor
New Thermostat
New ACT sensor
New Phase sensor
New Crank Sensor
Bosch 803 Dark green Injectors
T34.48 Turbo rebuilt 2000 miles ago
Standard Flywheel
Standard Cambelt Cover
Engine will be good for 360bhp+
£3800
07800 77 42 63
Old Nov 4, 2014 | 02:58 PM
Caddyshack's Avatar
Caddyshack
Looks Sweet, GLWTS
Old Nov 11, 2014 | 04:29 PM
Cossie-26's Avatar
Cossie-26
Any interest on this?
Old Nov 11, 2014 | 06:25 PM
jamie's's Avatar
jamie's
Not trying to spoil your for sale thread, but is that timed up properly?
Cams look out, just saying in case you havent run it like that yet
Old Nov 11, 2014 | 07:36 PM
Cossie-26's Avatar
Cossie-26
No i havent timed it up, i literally took all the pulleys off had them cleaned and painted and then put them back on! The engine will need to be timed up more accuratley! Thankyou.
Old Nov 11, 2014 | 07:39 PM
tony66's Avatar
tony66
Default timing
if you cant time it up put pistons half way in bore and remove belt-will save it getting damaged by somebody ...
Old Nov 11, 2014 | 07:41 PM
Cossie-26's Avatar
Cossie-26
Thanks tony will do.
Old Nov 12, 2014 | 08:31 PM
1300gt's Avatar
1300gt
Will you brake? Interested in alternator.
Thanks.
Old Nov 13, 2014 | 10:47 AM
Cossie-26's Avatar
Cossie-26
sorry would prefer to keep as a whole. thankyou
Old Nov 13, 2014 | 06:58 PM
smiley's Avatar
smiley
How many photos have you sold? Lol
Old Nov 13, 2014 | 07:01 PM
Cossie-26's Avatar
Cossie-26
None yet lol could make a fortune at 99p a go! Ha
Old Nov 17, 2014 | 09:37 AM
1300gt's Avatar
1300gt
Good luck with the sale. If you do brake first dibs on alternator
Old Dec 20, 2014 | 11:12 AM
Cossie-26's Avatar
Cossie-26
Engine now £3800
Old Dec 21, 2014 | 02:12 PM
Cossie-26's Avatar
Cossie-26
Now SOLD!
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
