Ford KA 2001 - Battery dies overnight
Old Nov 4, 2014 | 10:13 AM
SUMNER17's Avatar
SUMNER17
Default Ford KA 2001 - Battery dies overnight
I need some advise please, my Ford Ka's battery died a few weeks ago ( one cold morning) so I purchased a new one.
It's been fine until this morning (cold and frosty) and it wouldn't start again:
Nothing was left on overnight
Engine didn't even attempt to tick over when I turned the ignition
Can someone offer some advice?
Thank you!
Old Nov 4, 2014 | 11:08 AM
tony66's Avatar
tony66
Default battery
it could be a duff battery....
otherwise check for current with ignition off etc across fuses
also check bootlight/glove box light go off if fitted
Old Nov 4, 2014 | 12:07 PM
martysmartie's Avatar
martysmartie
An easy way is to measure the draw whilst removing fuses, that way you can isolate it to a particular circuit. A good place to start is looking at the radio.
Martin
Old Nov 4, 2014 | 12:21 PM
RichieST's Avatar
RichieST
As said above, radios on these go tits up and cause a drain. Try pulling it out and unplugging it for a few days see what happens.
FordJonah
Aug 22, 2015 08:31 PM
borboyous
Aug 22, 2015 11:17 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
druidgetafix
Aug 15, 2015 10:22 AM
