S2 heavy breathing
Old Oct 24, 2014 | 05:11 PM
rsmog33's Avatar
rsmog33
Default S2 heavy breathing
Think my s2 is in a bit of trouble
Massively overfuelling, spark plugs are dry but jet black and sooty. I know I can get a good set up and sort that out but I am more worried about its breathing. It seems under a load of pressure.
Still on mfi and original cvh. Its producing white smoke rings from the exhaust that stink of fuel and the coolant is boiling and bubbling after a run.
On cold start it barely gets going and idles crap until the revs pick up. Sounds awful. Checked the uprated breather and there are no blockages but seems like extreme crankcase pressure. Dreading the worst like rings etc..When I released a pipe from the breather to the metering unit there was a load of smoke.
Compression test showed 155 across the board. Any suggestions would be great. Not looking too good though
Old Oct 24, 2014 | 09:17 PM
studabear's Avatar
studabear
Cylinder leak down test may help, is it using oil and coolant?
Old Oct 26, 2014 | 09:41 AM
rsmog33's Avatar
rsmog33
Yes going to do leak down test this week. Not using any coolant. Slight oil leak from front crankshaft oil seal but nothing major. Oil levels are still good.
Just dreading the worst and don't want to spend too much to find bottom end is in trouble as would be a good contribution towards dropping something else in
Old Oct 26, 2014 | 10:36 AM
mattxr3i's Avatar
mattxr3i
Are all the breathers clear
Old Oct 26, 2014 | 03:18 PM
rsmog33's Avatar
rsmog33
Yes they are. Taken all the pipes and the breather off and cleaned through.
Old Oct 26, 2014 | 03:26 PM
mattxr3i's Avatar
mattxr3i
The tube that the breather attaches too on the block can block up too
Old Oct 26, 2014 | 03:55 PM
rsmog33's Avatar
rsmog33
Had that off too checked and cleaned. I don't have any blue smoke coming out , its white and produces perfect smoke rings.
I know white smoke is normally water burning so could be the HG on its way out but not sure that would cause excessive pressure.
Old Oct 26, 2014 | 04:52 PM
studabear's Avatar
studabear
If head gasket has gone it can pressurise the cooling system aswell as blowing steam out the back. If the cooling system is pressurised a sniff test could confirm the issue.
tankybaby66
Feb 6, 2016 02:24 PM
`spotty
Sep 25, 2015 11:41 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
landaqmabba
Sep 15, 2015 07:16 PM
