turbo oil return - Sump question
Good evening people,
To fit the Cossie turbo into my Westfield I've had to fit it upside-down. The oil return from the turbo is now lower than the oil return to the bottom of the block.
I'm going to have to move the oil return to the sump. I have a sump off my old CVH 1.6 engine.
Are the sumps the same on the naturally aspirated CVH as with the RS turbo, please?
I thought I'd read that the RST sump is baffled. Some of you must have done this as an upgrade to their engine.
Any recommended part I could use to plug the hole I will make in the block once I remove the return pipe?
Any pitfalls I could come across?
Thanks very much,
Neil
Thanks very much,
Neil
Matt Baxter
Sep 16, 2015 08:30 PM
lockie
Jul 31, 2015 10:03 PM
