cosworth engine
Old Oct 15, 2014 | 07:55 PM
westyre1's Avatar
westyre1
Default cosworth engine
For sale is my as new engine removed from my new build Motorsport car which I broke this is the last item left which like everything is as new put together in 1998/2004 new 200 bblock as new head all brand new parts used apart from crank which is 0.5 everything else is new all internals sump alternator w/p pas/pump cams valves everything .few marks on the rocker cover but un skimmed sump is new mounts manifolds t34 .63 turbo every nut bolt £4500 or might split if enough interest pics to follow
Old Oct 16, 2014 | 08:15 PM
Focosmitch's Avatar
Think you may be clutching at straws with an add like that, no pics or info on what parts used etc for that price mate.
Old Oct 16, 2014 | 08:19 PM
matthewpickup's Avatar
matthewpickup
is the cylinder head 2wd? if so and you want to break how much for a bare cylinder head ? posted to central scotlandd
thanks
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
