Doing away with air injectors
Yes.
But depending on the ecu features you may not need an external electronic boost controller. You can just use a solenoid run by a mappable signal from the ecu.
What ecu you looking at?
Thanks for the reply. I haven't quite yet decided but was just curious to know if it was possible. Good point about the running the boost control via the ECU as opposed to a stand alone, I will have to factor this in when deciding on ECU
I run an apexi avcr on my Westie because it gives me boost mappable to gear, rpm, road speed or throttle position.
Internal gate Gt3076 and still running L8 at the mo.
Only downside is the ecu cannot dial down boost when other conditions are out of certain parameters such as air charge temp, knock etc. your Weber-marelli ecu controlled air injectors are actually safer than an electronic boost controller for that reason.
That said the avcr is a great piece of kit and controls boost perfectly.
If I go standalone ecu I may still use it but build in over riding safety features.
Edited to add:
If I had of had these safeties built in previously I wouldn't be rebuilding a melted pistoned engine now!
Edited to add:
Edited to add:
Edited to add:
Mark
Mark
mk3ste
Oct 17, 2021 10:09 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
