Knacked valve and next step advice.
Evening,
In a post couple weeks ago, I mentioned my lost compression in cylinder 3.
I got the head off today, and found a significant gap in the exhaust valve, it also looks as though the valve is bulged. Also, the top of piston three is bone dry, can I assume this is down to the valve problem and not something else?
On the plus side, the cylinder walls look spot on.
Ive never worked a head before, but Im fairly competent in the old spanner department.
Thoughts on my next step, should I,
rebuild with standard bits,
take the opportunity to port & polish and uprated (possibly out sourcing to a experienced builder )
source a ready uprated head (such as the NMS one in the for sale section).
Any thoughts and advice very welcome,
Cheers guys
Wayne
Cheers guys
Wayne
No, the rocker and lifters etc are all still in situ. First thing I tried was torquing the rockers, but its still rattling slightly.
Engine was set to TDC, and the other 7 valves are sitting closed flush against the head. Only no3 exhaust is sitting like this.
Ive turned the cam one full revolution, and the valve doesnt shut fully. It one point there was a 3mm gap. It looks like its def bent, but there is no damage to piston, wallls, bottom of stem etc.
Ive been through the history, there is receipts for a bottom end rebuild, but it looks like the head is still original. Time for a rebuild
Im gonna strip it this weekend, once my Supra guru friend has had a look at it.
I was searching around at the weekend, and found a company called CNCHeads, that do a fully gasflowed and matched head for 350 (inc exchange)
Anyone used them?
Anyone used them?
TC-ST3
Sep 26, 2015 04:47 PM
