idle control valve
Old Oct 8, 2014 | 09:39 AM
jimhc's Avatar
jimhc
big jc
Default idle control valve
I just bought a complete throttle body with 4x4 plenum and inlet (for 20 quid well pleased) I'm at my work cleaning everything and I'm just curious would steeping the idle control valve in red diesel or petrol/2 stroke mix be ookay as that's all I have at work?.
Old Oct 8, 2014 | 07:23 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Petrol or carb cleaner. I dont think 2 stroke oil will help any more. Have you taken the small nut and springs out and cleaned the piston bit up inc it's tiny holes??. An old tooth brush and sewing needle will do the trick.
Make sure the nut is in the same position you took it off in.
Old Oct 8, 2014 | 08:13 PM
The Crocodile Hunter's Avatar
As above take it apart to clean it properly, soaking them in something doesn't always work or only works for a short time as it won't completely clean it around the piston where they get stuck
Old Oct 8, 2014 | 09:29 PM
jimhc's Avatar
jimhc
big jc
How do you stop shaft from spinning?
Old Oct 9, 2014 | 06:45 AM
kosienutter
Shaft shouldn't spin I think??
Old Oct 9, 2014 | 07:27 AM
jimhc's Avatar
jimhc
big jc
Okay cheers I will have a look at breakfast time.
Old Oct 9, 2014 | 09:42 AM
jimhc's Avatar
jimhc
big jc
Done all stripped cleaned and rebuilt just to go home fit and see how it goes and it's okay I will be stripping the other 1 done as well thanks for the advice guys.
Old Oct 13, 2014 | 09:32 PM
matthewpickup's Avatar
matthewpickup
dam wish I read this before I bought a new one
I just put mines in a tub of fuel and powered it on and off but didn't work so I thought it was passed it , going to try this now lol
Old Oct 20, 2014 | 09:14 AM
jimhc's Avatar
jimhc
big jc
It's made a big difference. Now just to fix the hesitation and slight splutter haha.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
