which way round do you fit lowering springs
Old Oct 7, 2014 | 07:11 PM
tlr_rst's Avatar
tlr_rst
Default which way round do you fit lowering springs
right guys, got myself some new lowering springs, can't be hard and all that, which way round do you fit them as if you look at them one end has more of a compressed coil closer together than the other end, so what I'm asking is does the "more compressed" bit sit at the top or does it sit at the bottom, hope that makes sense
cheers fellas
Old Oct 7, 2014 | 07:35 PM
studabear's Avatar
studabear
Have you looked for any markings on the springs?
Old Oct 7, 2014 | 07:55 PM
dazrsturbo's Avatar
dazrsturbo
more compressed at the top so you can read the spring markings
tlr_rst's Avatar
tlr_rst
yer no markings, no instructions in the box, they are gmax springs from demon tweaks
Old Oct 7, 2014 | 09:16 PM
Chas's Avatar
Chas
A number of peeps from other marks always suggest to fit the end of the springs with more coils at the top towards the top of the strut.
Old Oct 7, 2014 | 09:30 PM
RichieST's Avatar
RichieST
As above, closest coils at the top. but to be honest it doesn't really matter. If in doubt I have fitted them before with any numbers etc on them the right way up.
Old Oct 8, 2014 | 04:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Send them back and buy some decent ones! lol Gmax are awful, possible won't even sit level front to back.
Old Oct 8, 2014 | 06:07 PM
dazrsturbo's Avatar
dazrsturbo
well said! fully agree
Old Oct 10, 2014 | 07:05 PM
tlr_rst's Avatar
tlr_rst
are they not as good because why???
at least they will be better than the rusty corroded xr3i springs that were put on it in 98'
they are the only springs i could find that were not really dropping it much, i didn't want it lowered i chose them because it dropped it by the smallest amount 20mm.
otherwise id be using unknown brand from local motorfactors or eurocar parts
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
