dump valve setup fiesta RS Turbo issues
Old Oct 6, 2014 | 08:49 PM
defendant's Avatar
defendant
Default dump valve setup fiesta RS Turbo issues
Hi All,
Have recently bought my first turbo ford. The dump valve doesn't seem to be working. The piston does not open under acceleration. Below is an image of the setup, is this correct? (the long blue tube running off to the right is connected to the baileys dump valve)
The boost gauge on idle shows -10 psi and under acceleration the boost reaches about 5psi even though the car is setup to run 18psi. Is this related to the dump valve issue?
Old Oct 12, 2014 | 11:08 PM
Oranoco's Avatar
Oranoco
Take the dump valve off and blank the boost and vacuum hoses. File dump valve in the bin, job done.
carlo
24
Oct 5, 2015 08:20 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
knight19770
Aug 4, 2015 12:36 PM
