Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2.0 tdci vss speed sensor question
Old Oct 1, 2014 | 03:06 PM
andyt1992's Avatar
andyt1992
Default 2.0 tdci vss speed sensor question
Hi,
Does anyone know where the speed sensor is located on the 2.0 tdci focus had a good look around but can't find it. also cant find a reference to it in the Haynes manual.
Any help or pictures etc would be very helpful!
Thanks,
Andy
Old Oct 2, 2014 | 08:51 AM
andyt1992's Avatar
andyt1992
anyone please? I really cant see it on the transmission housing anywhere and my car keeps cutting out after a mile or so..
Old Oct 2, 2014 | 11:32 AM
Piston Broke's Avatar
Piston Broke
its in the gearbox mate top near the bulk head
Old Oct 2, 2014 | 12:00 PM
andyt1992's Avatar
andyt1992
Cheers fella, I'll report back tonight would you know if it's accessible without removing other parts?
Old Oct 2, 2014 | 12:31 PM
Piston Broke
from the underside looking up yes you can get to it mate, there is a pin holding it in and can be a right twat to get out
Old Oct 2, 2014 | 02:18 PM
GVK.'s Avatar
GVK.
If its a mk2 Focus (or even some very late mk1)... they don't have a VSS the vehicle speed info comes from ABS via high speed can to PCM and instruments.
Old Oct 3, 2014 | 08:51 AM
andyt1992's Avatar
andyt1992
This is correct after another hour or so swearing and screaming last night I still didn't manage to find the vss... it doesn't have one despite the garage saying that's what I need and the part being on the system under the reg!
So the next question is with diagnostics code c1155 N/S ABS wheel speed sensor.. should I just jump to buying the sensor and fitting it or is there any other investigations I can do to check the faults origin?
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
15
Oct 7, 2015 03:43 PM
Kam B
Sep 24, 2015 10:40 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
