boost controler ?
Old Sep 27, 2014 | 05:22 PM
luxembourgrst's Avatar
luxembourgrst
Default boost controler ?
hey on my stage 2 turbo I dropped the boost to 17-18 psi
with the wastgate screw
but the turbo only starting charge at 4000 rpm
how can I do it that it charge earlier but stay the same maximom pressure of 18 psi?
with a boost regulator?? is it good or not every time when you setup the boost you also need to resseting the AFR ?? no
bad idee for our rs turbos?
thanks
Old Oct 1, 2014 | 03:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Something else is wrong if your stage 2 T3 is making boost that late, boost leak maybe? Weak actuator? Retarded timing?
Old Oct 1, 2014 | 06:42 PM
luxembourgrst
well it s not exactly 4000rpm but like 3500 rpm
the question is more like if I turn the srcrew on the actuator to have low boost the turbo is charging more at light rpm if I turn it to have more boost It s charging earlyer
Old Oct 2, 2014 | 05:09 PM
Red_bull's Avatar
Red_bull
If you turn it to have low boost and it starts making more boost you probably turn it the wrong way. Anyway your story sound strange. But mate why don't you go to a tuner again i recommend you. They know engines and they can help you with all problems you reported. Get is sorted and enjoy the car!
Like these ppl might be able to help you!
http://www.br-performance.lu/en-lu/home/
and i already saw more tuners. Start calling and check how they react on your questions. If you notice doubt in their story onto the next
Old Oct 2, 2014 | 07:24 PM
luxembourgrst
I gonna call them
Old Oct 2, 2014 | 07:28 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Set the waste gate to 9 psi preload or half a hole if you have a garret -31
Fit a 3mm restrictor to the r port of the amal valve the w port remains empty the c port retains the std 2.5 mm
Old Oct 4, 2014 | 08:51 AM
luxembourgrst
I have a -31 garret
well good idea my max turbo psi is 18 because the turbosystem ecu chip
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
