Argh help!!
Old Sep 25, 2014 | 05:45 PM
growlingchim's Avatar
growlingchim
10 Year Member
Default Argh help!!
Right I've e had a wobbling on the front of the 4x4 since I bought it so I've just bought new EBC disc and new standard pads to go on. Someone had peeviously snapped the bleed nipple in the drivers caliper so I've had to order a new one.
So whilst I'm waiting for that to come tomorrow tonight I decided I'd build up the passenger side. Got everything back to gather put the RS7 back on and the spoke is touching the face of the caliper???
Ive taken the disc off and checked and it identical to the old one, I cannot work it out can anyone help?
Thanks
Graeme
Old Sep 25, 2014 | 07:22 PM
stevieturbo's Avatar
stevieturbo
C**t
The disc flange must be thinner.
Old Sep 25, 2014 | 08:53 PM
growlingchim
10 Year Member
Cheers for that mate just checked though and there exactly the same thickness??? 😭
Old Sep 25, 2014 | 08:58 PM
Cossy Mike's Avatar
Cossy Mike
They the right discs? 2wd 4wd?
I know RS7's run close but shouldn't touch.
Will they clear when the piston comes out and pulls the caliper in? should give an extra 5mm at least
Old Sep 25, 2014 | 09:29 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I reckon that's the answer
Due to the pads being new and therefore thicker, the caliper is sitting further out towards the wheel. Hopefully once the pedal is pressed it will bring the caliper a bit closer in.
scottyfocus
28
Dec 9, 2010 12:47 PM
Rhys
Jan 10, 2007 02:34 PM
Rhys
Jan 3, 2007 06:36 PM
lamar69er
May 3, 2006 03:00 PM
