gold passivate on suspension bolts.
Old Sep 23, 2014 | 07:20 PM
kiwikermit's Avatar
kiwikermit
Default gold passivate on suspension bolts.
As per title. How many folks have had their original blue coated bolts zinc plated and gold passivated? Has anyone ever had a problem with them snapping due to brittleness caused by the process?
I am tidying up my suspension and have considered getting it done but the Sierra RS workshop manual says "mechanical coating only" which rules out any plating.
Old Sep 23, 2014 | 07:51 PM
Albertodelgado's Avatar
Albertodelgado
hi I did all my bolts on both cars Sierra Cosworth 2wd and 4x4 from suspension to drivetrain most of them were original blue bolts and now gold zinc plated.
No problems whatsoever. It's true that they get a little weaker after the process but not that much.
Old Sep 24, 2014 | 07:40 AM
kiwikermit's Avatar
kiwikermit
Looks nice. Excellent job mate.
Old Sep 24, 2014 | 07:41 AM
cossynut2's Avatar
cossynut2
10 Year Member
Wow!!! that looks like brand new!
Old Sep 24, 2014 | 09:14 AM
Cossy Mike's Avatar
Cossy Mike
Me to, never had a problem. Just make sure they are correctly rated 8.8, 10.9 or 12.9 depending on which ones your doing
Old Sep 24, 2014 | 10:58 PM
kiwikermit's Avatar
kiwikermit
Cheers. I planned to give the original bolt a new lease on life so ratings should be correct. I was thinking the torx bolts for the cv joints on the rear axle are best left alone probably.
Did you do the power steering pipes too? They look nice.
Old Sep 25, 2014 | 04:45 AM
Cossy Mike's Avatar
Cossy Mike
Yeah leave the cv joint bolts unless you can find new ones.
Make sure you take off all the blue coating before you send them for zinc, you'll get a better finish.
Power steering pipes were also done
Old Sep 25, 2014 | 06:49 AM
steveboyslim's Avatar
steveboyslim
Google 'Hydorgen De-embrittlement' before you decide.
Steve
Old Sep 25, 2014 | 08:35 AM
kiwikermit's Avatar
kiwikermit
I just had a nosey on Google. Long story short I need to be sure the electroplaters know what they are doing and get the high tensile parts in the hot oven immediately to bake the hydrogen out before it can do any harm.
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
lime
Sep 25, 2015 06:56 PM
