Steering column help
Old Sep 21, 2014 | 01:47 PM
simonmcf's Avatar
simonmcf
Default Steering column help
Put together the steering column this morning and replaced all the bushes. Should the thing that holds the lock be banged down to cover the slit/opening on the Column? Cheers Simon
Old Sep 21, 2014 | 02:24 PM
GINGExR2 T's Avatar
GINGExR2 T
You need to put the key in the barrel and turn it forward so that it goes further down.
Ginger
Old Sep 21, 2014 | 02:25 PM
simonmcf's Avatar
simonmcf
Ah cheers! Should it compress down and cover the slit on the column
Old Sep 21, 2014 | 02:26 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
your missing an alloy part the goes over the tube first to slip over the 2 bolts that face you end on , as you sit in car,
yes the lock assembly slips down to about an inch before it tapers to the wider part of the tube , so no slot is visible
Old Sep 21, 2014 | 02:33 PM
mk2grp1's Avatar
mk2grp1
have you been doing burnouts on your wheelbarrow ??
Old Sep 21, 2014 | 03:53 PM
simonmcf's Avatar
simonmcf
Cheers yea have that on now and the stalks! Ah yea so much it blew up!
Old Sep 21, 2014 | 04:42 PM
focusv8's Avatar
focusv8
Looks like he's been nailing it, or it's screwed??
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
