help please..
Ok so i bought my first zs yesterday.. really happy with it!
I have a halfords special air filter lol.. had it laying around in the garage..
Stupid question maby but can this go onto my new car? Mk5 zs.. and where should i join it? Do i take the block with plugs on it off? Or attach to that section? Thanks
An aftermarket air filter will probably loose you power as it will just suck in hot air from the engine bay. The standard set up is good enough, if you want the best performance then put in a performance panel filter into the original air box. If you want noise then remove the air filter box and mount your new filter on to the end of the air flow meter, but be prepared for it to use more fuel and probably not perform quite as well.
bonus_boy
20
Apr 5, 2009 07:28 PM
