Rolling road Qs
Old Sep 21, 2014 | 10:54 AM
The Underdog's Avatar
The Underdog
you cant fix stupid
Default Rolling road Qs
hi. im just wondering about how a rolling road calculates flywheel bhp from the wheel bhp.
what im wondering is for my car now with a lightened flywheel and lightend pulleys and no air con it has gained more wheel bhp but obviously not flywheel. i understand that bit.
but what im confused about is how a rolling road would interpret this. if it sees more wheel bhp is it going to over calculate the flywheel bhp? does that make sense. so for instance if my car standard was a genuine 170bhp (not likely) and stock for argument sake it had 130 at wheels and my modified one had 140 at wheels would the computer inflate over the 170 when it estimates flywheel figures?
am i making sense? hope so but thanks for input
Old Sep 21, 2014 | 11:09 AM
RichieST's Avatar
RichieST
When it hits the Rev limiter the operator puts clutch in and allows wheels to stop turning by themselves. Time taken for wheels to stop can be calculated into how much resistance is in the transmission, thus how much power is being lost, if you get me!
Old Sep 21, 2014 | 11:13 AM
The Underdog
you cant fix stupid
but would it still give a correct flywheel figure or would it be over estimated because of higher wheel figure or am i seeing it all wrong?
Old Sep 21, 2014 | 11:24 AM
Fullflush's Avatar
Fullflush
Put it on a hub dyno
Old Sep 21, 2014 | 11:26 AM
RichieST's Avatar
RichieST
What you have done is made more power at the wheels by making less resistance through the drivetrain / ancillaries.
The RR would see the higher power at the wheels, but also less resistance because the wheels are taking more time to run down to a stop, so it should then calculate the same flywheel HP.
Old Sep 21, 2014 | 11:29 AM
RichieST's Avatar
RichieST
The only thing a hub dyno takes out of the equation is an incorrect power figure from wheelspin and instability on the rollers etc, it would still need to calculate losses through the drivetrain to calculate a flywheel figure. The most accurate way would be to remove the engine and measure power directly from the flywheel.
Old Sep 21, 2014 | 11:32 AM
The Underdog
you cant fix stupid
thanks i understand it now.
Old Sep 21, 2014 | 11:36 AM
RichieST's Avatar
RichieST
Don't forget also your lightened flywheel will make the car accelerate quicker as there is less weight to get turning, however when on the run down, it will stop quicker, as there is less weight to keep it rotating. These two figures should balance themselves out though to not affect the final reading.
Think of it as a roundabout in a park. When it's empty it will be easy to get spinning, but let go and it will stop quickly, but put a load of fat kids on it and it will take a lot of effort to get going to the same speed, but let go and it will take much more time to come to a stop!
Old Sep 21, 2014 | 11:46 AM
The Underdog
you cant fix stupid
what if a few of the fat kids fall off? lol
Old Sep 21, 2014 | 11:47 AM
RichieST's Avatar
RichieST
Then it'll just be funny lol
Old Sep 21, 2014 | 11:58 AM
Fullflush's Avatar
Fullflush
I don't get why anybody cares about flywheel power. You can only use the power at the wheels.
Old Sep 21, 2014 | 01:19 PM
BigPeBe's Avatar
BigPeBe
I think the reason flywheel power is still preferred most of the time is that car manufacturers have always had a habit of announcing flywheel power on their specs for their cars. So it's easier to compare power outputs and everyone has kinda "calibrated" their brains for the flywheel output so it's easier to understand what is lots and what's not.
I agree that it would be much more logical to talk about power on the driven wheels, but I still prefer using flywheel power because it just seems to be the way around.
Old Sep 21, 2014 | 05:10 PM
scoooby slayer's Avatar
scoooby slayer
it will be hugely dependant on which dyno you use as to what correction needs to be applied to get a close estimate at the flywheel power imo.
there will always be people saying flywheel figures are rubbish I just ignore them and do as I please
surrey rolling road is a dyno dynamics dyno and known for being fairly accurate, certainly not generous anyway.
so here is the flywheel plot from my gtr at 1.4 - 1.6 bar of boost
now assumeing that 2wd correction was applied (which is the minimum it can add) then the wheel power for that run was about 710 WHP with 18% added for rwd losses that the dyno applies.
so we have a dyno dynamics dyno measureing 710 WHP from my car at 1.4 - 1.6 bar.
now heres a dynapack plot from my gtr on the exact same 1.4 - 1.6 bar tune
so dyno dynamics made 710 whp, dynapack made 812 whp.
so the dyno dynamics needs 130 hp adding to show correct flywheel power, dynapack needed 28 hp adding to show the correct 840 hp it has at the flywheel.
there we have the same tune run on dynos operated correctly with no fudgeing involved and the wheel/hub figures varied by 102 hp !
the tiny gains your talking about with the flywheel being lightened can easily disappear and more through dyno variation, if you didn't get it dynoed before the mods I don't think you will be able to make a good comparison now imo.
and your aircon will make no difference, yes you've shaved a little weight but when the aircon isn't active the clutch isn't engaged so the pulley spins freely, an air con pulley with no air con engaged wouldn't even sap 1 hp imo.
Old Sep 21, 2014 | 08:10 PM
The Underdog
you cant fix stupid
thats just mental scooby.
boeb
Jan 9, 2020 05:11 AM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
Mikersturbo
Sep 27, 2015 07:43 PM
