ford p100 engine convension
Old Sep 20, 2014 | 09:22 PM
socrates's Avatar
socrates
Default ford p100 engine convension
Hello guys, i own a p100 in cyprus it a 1,8td,
the whether is hot and overheated i crack 3 cylinder head of my engine, and i dont find parts in cyprus, my thoughts are tha put a more common engine for parts and not overheat, any ideas?
Old Sep 20, 2014 | 09:41 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
1.8 or 2 litre sierra pinto very easy to fit
Old Sep 21, 2014 | 07:08 AM
socrates's Avatar
socrates
yes but the issue is that is hard to find in cyprus
Old Sep 21, 2014 | 11:59 AM
mk2grp1's Avatar
mk2grp1
pinto also fitted into ford transit,
escort / mondeo /focus 1.8 zetec
+ mondeo and focus use 2litre zetec,
they are fuel injection units so many wires are needed,
but you can convert to carbs
Old Sep 21, 2014 | 12:00 PM
mk2grp1's Avatar
mk2grp1
ford dohc L4 engine approx. year 1990
Old Sep 21, 2014 | 12:20 PM
socrates's Avatar
socrates
a ford transit connect will fit easy?
Old Sep 21, 2014 | 12:24 PM
mk2grp1's Avatar
mk2grp1
not as easy as the engines I mentioned , but certainly possible
Old Sep 21, 2014 | 12:26 PM
socrates's Avatar
socrates
what is the cheepest and easyest engine to swap?
Old Sep 21, 2014 | 12:51 PM
mk2grp1's Avatar
mk2grp1
pinto requires very little electric wiring, , engine mounts will be simple to find
and they were carb engines so inlet manifolds with carbs will be cheapest
L4 engine and zetec require more parts , but very good units
the commonest ford engine in the scrapyard is possibly the cheapest
Billy_RS
16
Oct 11, 2025 09:41 PM
